Mini Sanding Discs For Bowl Sanders
niall Y
1 Nov 2018
CARDIGAN
I've recently acquired a bowl sander, which uses a series of mini sanding discs. It came with two sets of discs in 1 inch and 2 inch sizes. And, there are five different grits ranging from 60 to 320 included.
I've had a cursory look around for replacement discs with Velcro backing, but I would like to know if other turners have discovered any real price advantage from making their own.
They can be of variable quality and price. If you can accept the principle that they don’t need to be perfectly round (some folks use square!) they are cheap and easy enough to make. You can actually buy punches in the 2” size if you want perfectly round ones but I can’t remember how much they are? I made a little sanding pad recently to go on a flexible drive and just used some roughly scissored Abranet. It worked just fine.
I use 50mm and 75mm felt-backed discs, which I get from various places. They are mostly of various quality, but that's not all that important to me for the amount I use them. As Phil suggests, I also cut oversized square or hexagonal shapes from rolls of felt-backed paper. They are great for tight curves. When the discs are near the end of their life, you might squeeze a bit more out of them by using them wet when hand sanding.
Plenty available on FleaBay and Amazonkia, quality can dop, but for price the oddcrap set not a problem, most are acceptable to fine. If there is a problem, to me it's more trying to find sets that don't include 50% of grits that are way too fine, unless your sanding resin or CA finishes on pens.
I try to buy sets of single grit sizes, but not always easy to find.
