Metal cutting Countersink Bit needed.
mahking51
15 Nov 2004
Nr Dorchester Dorset
Hi All,
I just wondered if anyone can point me in the right direction to get a METAL CUTTING 90 degree Countersink bit that will go in my pillar drill?
I need to c/sink some slotted screw heads flush into a piece of 3mm guage plate and have bodged it so far with a woodworking bit which justs gets hot and 'smears' the steel giving a raised lip which has to then be removed. I'm also probably using too high a speed. Said bit is then totally burned and u/s.
When done the screws have a small groove around the heads as the c/sink is larger than needed, looks terrible!
Any thoughts welcome please.
Regards,
Martin
Screwfix do the Ruko ones, J&L do several pages worth from budget to carbide
Make sure you use it on the slowest speed, cutting fluid will also help if they are steel hinges. Your woodworking Csk is likely to be carbon steel you need HSS or better for decent results.
If your guage plate has got very hot it may well have work hardened due to the higher carbon content, think about annealing it before you do more work
Jason
Ax do 'em as well, in fact any decent tool shop/supplier will have them.
Roy.
