WoodYewToo
Probably going to buy a new Metabo HC260C planer thicknesser - but need to check if it it will run on a standard 13Amp socket.
I've seen some comments on here from a few years ago that say fuses can sometimes blow on these machines.
My limited understanding of maths suggests... if it's got a 2200 watt motor and we divide that by 240volts, we get just over 9 amps. So does that suggest it should run on a standard 13A socket (I don't have any 16A sockets)? Or is the startup current going to be significantly higher than 9amps?
Thanks.
Thanks.
