No skills
I would use glue direct from the bottle (1 litre sized) and just run a bead down the centre of the board edge. Let the compression of the components spread the glue out for you. Once assembled have a quick nose round and clean up any squeeze out.
FWIW.
As above some 25mm brads or staples fired in at an angle would prolly do the job for the back once the glue is set.
FWIW.
