bp122
Expert at Jibber-Jabber
Hi all
I haven't really bothered with building a new workbench from scratch, as I cannot really justify the cost and time at this stage, where I have a few small scale projects coming up (shoe cabinet, closed computer cabinet, picture frames, shelves and draws for various parts of the house etc)
So, I came across a solid pine dining table which someone was selling on the popular sticky tree website for £20 delivered. It has a heavy 50mm thick top and round legs, hasn't got a brilliant apron, but is quite stable once the top is screwed on. It is the right size for my work area in the garage but just over an inch lower than I'd like. The top itself is heavily varnished but I can't find a spot which is flat for longer than 3 inches I have also trimmed the edges which had a fancy routing on it (but was uneven) with my track saw, so it is uniform and straight.
I am thinking of attaching an old record face vise to it (which I restored myself to an operable condition) and to give the table a bit of height and heft at the top, putting two sheets of 18mm MDF glued together and screwed on top of it. It will give it a flat surface and the fact that two MDF sheets are glued, it might keep it flat for a while.
Down the line, I'd like to create a tool draw, a couple of cabinets under it to aid the storage of all frequently used bits and bobs.
1. Is this a good idea, and has anyone else done this?
2. If yes, what sort of finish should I apply on it?
3. Or would it be a better idea to stick one MDF sheet to a melamine faced chipboard
4. same question as #3, but use a flat hardwood table top from a different table instead of the melamine?
5. Also, instead of fitting a vise, for my application, would a bench bull be a better solution?
I won't be banging a lot on this table, ex: chisel work or carving etc. I just need a reliably flat table for assembly and planing
I also plan to drill a few holes for dogs / holdfasts, later on of course, as there isn't a great deal of room to attach clamps on this.
Please share your thoughts and experiences.
Best regards
B
Best regards
B
