CWatters":2wfukhg3 said:If a workshop is classed as a Habitable Room then the insulation, double glazing and heating must meet the Building Regs. On another forum someone is having problems modifying a home office based on a portacabin. Building Control are insisting that it's a habitable room and therefore the heating system must meet the regs. The latest regs require you to use a condensing gas boiler and appear not to allow electric fan heaters or portable gas fires (too much Carbon).
Jim Linn":3e83scqn said:
CHJ":2a7cj73x said:CWatters":2a7cj73x said:If a workshop is classed as a Habitable Room then the insulation, double glazing and heating must meet the Building Regs. On another forum someone is having problems modifying a home office based on a portacabin. Building Control are insisting that it's a habitable room and therefore the heating system must meet the regs. The latest regs require you to use a condensing gas boiler and appear not to allow electric fan heaters or portable gas fires (too much Carbon).
Be pushed to enforce that around here. No mains gas supplies.
