Maths help required
I always do a small test sub prototype of anything that needs to be fitted to an external component to check the tolerances, then build up to the full design and then print. Doesn't remove all the risk of distortion/shrinkage under cooling, but usually saves a lot of time.
Sounds like a good idea (y) Thank you
