Your technique is a great idea, which I will immediately steal, but I like my cheap brass wheel gauges because they're a LOT more comfortable and easier to set reasonably accurately.Jacob":r6x09abo said:yep a handful of ordinary cheap gauges is best. Different shapes and sizes is useful too.
Another trick is to work backwards (and forwards) - you mark the last 4" or so then move back and mark the next 4" so you are running into the mark you've already made - and so on. This way if any of your marks has slipped into the grain and gone off it will be only within the 4" and should be obvious. Whereas if you mark in one pass from near end to far end the whole line might have gone off without you noticing it. Sounds complicated but it isn't.
yer ordinary wooden gauge is also comfortable to use which is important if you have a big pile of marking up to do - you could be at it all day on a big multiple project, which would make those pointlessly expensive metal versions even less useful.
Saint Simon":2e8r5hqq said:Derek, the knob is for pulling the gauge so that its "fence" is pulled hard against the edge of wood to be marked. I'm sure most people are happy with a one handed grip on marking/cutting gauges but I like to pull with my second hand and this mod, which I copied from a Stanley 70 1/2, helps me do this.
Any resemblance to Mickey Mouse is entirely fortuitous.
Simon
Saint Simon":3ffsgpac said:Derek, the knob is for pulling the gauge so that its "fence" is pulled hard against the edge of wood to be marked. I'm sure most people are happy with a one handed grip on marking/cutting gauges but I like to pull with my second hand and this mod, which I copied from a Stanley 70 1/2, helps me do this.
Simon
Hi Simon
Just checking why you feel there is a need ... if the knife the correct way around? Flat side away from you pulls the fence against the side of the board. But flat side towards you will push the fence away from the side of the board.
And do you take light cuts first? Or go in hard?
Regards from Perth
Derek
