Hello,
I would like to buy a universal marking gauge that works equally well across and with the grain. It will be my first one.
I have ruled out a pin marking gauge as it does not work very well across the grain. My budget is up to 40 pounds + shipping costs.
I am interested either in wheel marking gauge or cutting gauge (if it can work reasonably well with the grain and does not get pulled to the grain direction).
Can you give me some recommendations within my price range?
At the same time, I have decided to build a cutting gauge from ash (I have either ash or red oak at home at the moment).
Can you please advise me what are the important things when building my own marking gauge, besides having a flat fence? And if it is better to use a wedge or a screw to tighten it up.
e.g. Does the stem must be perfectly perpendicular to the fence in both directions ( I can get it out of square either with forward-backward tilt or up and down tilt). If I manage to build it too tight, humid weather can render it unusable. I have already broken one that I have bought (made out of beech) when it was humid weather.
Thank you very much.
