woodpig":2vlrm1pf said:6mm isn't very thick for a bowl scraper. The last one I bought was 1 1/2" x 3/8". It was quite expensive but you get very little vibration with it.
It's a small world -Tregaron is only about 6 miles east of me..graduate_owner":2k33llu4 said:Tregaron is only 20 miles fom us here in Caio, although I will admit we are just about due south from you so I expect I am indeed a southerner by comparison. As it happens, Carmel is also about 20 miles almost due south from us.
duncanh":1ftbgil9 said:You can save a lot of time grinding down to this shape by cutting off what you don't need using an angle grinder with a thin metal cutting disc. Assuming you have an angle grinder
Yes, it's a gouge sharpening jig. If we put a gouge on a flat rest, tilted to the correct angle, & rolled the gouge from side to side we would get a conventional, straight across grind similar to that on a spindle roughing gouge. To grind the wings, the handle has to be swung in an arc as the gouge is rolled - & that is what the jig does.Claymore":2ikrrc2b said:pardon my ignorance Naz but is it for sharpening? also why do the chisels need to be so long? is it for better leverage while turning big stuff?
Sawdust=manglitter":1vn4vfum said:duncanh":1vn4vfum said:You can save a lot of time grinding down to this shape by cutting off what you don't need using an angle grinder with a thin metal cutting disc. Assuming you have an angle grinder
I did think about doing that, but i was concerned that it would heat up too much and mess with the heat treatment of the steel?
NazNomad":2ogbzr8k said:Finally got my 3mm tap and finished this ...
25½'' overall, 14'' sticking out of the handle.
10mm carbide cutter from Fleabay seller 733gtfly, who was very patient and helpful despite my stupid questions about the screw sizes.
I find it's a bit aggressive unless I turn it to about 45 degrees, but that is most likely down to my own inexperience.
All in all, I'm a happy bunny.
p.s., I left that bowl a bit thick due to the almighty crack in it ... Don't need to lose another window yet. :-D
woodpig":zgkm2mgc said:Surprised you needed a 3mm screw as I've been using 4mm screws on my 10mm insert tools.
NazNomad":3pgwy7f6 said:The seller makes and sells complete tools. He supplies (and uses) 4mm screws with a 12mm bit and 3mm screws with a 10mm bit, he said from his experience the 3mm fit better. I bowed to his experience. I can always increase to 4mm if need be.
