Have you actually squared & planed your stock or is it simply sawn to the dimensions?
I've already squared and planed the sticks (sorry, rails, stiles or whatever there're called) ready for rebating.
Richard
Blimey Richard! You think the saw is risky?? Last week you were going to tenon and mould everything on a spindle moulder even though you had zero experience with using one??![]()
Mortices, and tenon cheeks, first, then mouldings and rebates, then tenon shoulders last.I've already squared and planed the sticks (sorry, rails, stiles or whatever there're called) ready for rebating.
Richard
Just read this. I was going to do rebates first and then mortices and finally the tenons. Watched a guy on Youtube do it this way.
Any problems with this?
Richard
Generally it's easier to mark up everything and cut the mortices and the tenon-cheeks whilst everything is still square, not least because you can still see the marks.No right or wrong way, it all depends what kit you have and how you are doing it.
I guess you mean featherboards?I need to make a higher fence for my TS to allow the top weatherboards to be clamped. Is was thinking of using 25mm MDF which I've used before for router jigs. Is there anything better?
Richard
Stick with the router! If you do have a go with the TS do a lot of small trial rebates firstIt was why I thought it would be better to space the featherboard up and pushing against the main stock rather than on the slot being cut.
I originally asked you about have the waste on the other side of the blade to provide a safe place for the waste but you were concerned about any wobble would impact into the main section. Do you think this would still be a major problem especially with the featherboards raised?
