Hi again - I've found that a bench belt sander with a 40-grit belt is quite good for cleaning and squaring the ends of steel bars up to say 10x10mm, but it's sometimes not easy keeping the bar perpendicular, even by using a hole in some aluminium block to hold it.
What I'd like is a metal file like a sanding disc, that's faster and more durable, and more easily controllable.
Any suggestions, thanks!
