Might as well test run it with the table off, and guides outta the way...
Plenty of things you could find out, what wouldn't be possible to find out otherwise.
Tramming the wheels, checking if the faces might have 0.2mm discrepancy,
then you could align the wheels, and motor to the upper wheel datum
I could explain all this but my internets too slow to upload pics,
and not much point if it'll be deleted.
I've posted this elsewhere, like on the bandsaw forum and the Creek in more detail,
I thought I posted my more recent findings already on my bandsaw thread, but it must've been someone else's post.
Internets too slow to upload pics, parsing response error, will have to update my thread,
but all that's on the Ozzy bandsaw forum, best read backwards, just like all my posts, lol.
Tramming to check for 0.2mm discrepancy
my upper wheel had 0.5mm, what translated to 4mm variable lines on the base.
Impossible to align wheels with this method if so...
Likewise the wheel and carriage must be solid before doing such...
Use masking tape to protect your paint
Mark where you can hear if needing so
Custom file handle, (would be a good idea to select stock so you can't use it backwards)!
Now the wheels are trust-able
I've got the measurements down, basically thick enough to clear the chassis "waist"
gotta be over an inch on my machine, I had this 40mm timber, length determined to suit this tight spot in the chassis below, and wide enough 92mm, to register the beam against.
Upper wheel datum line drawn, (upper wheel is not adjustable like the lower wheel)
hence why I'm calling it so.
Use a pen, not a pencil
Then you could check the motor and see if it matches the upper wheel,
(and cross your fingers if it's a face or flange mount motor)
View attachment 166973 and is coplanar,
This inch thick plank is best as long as possible for balance, and motor might need be lowered
and cinched down again (beware of overdoing it with that)
Bearing to clear the shaft, was handy, but something else would do rightly
Once assembled, match the lower wheel to those lines,
and don't pinch the shaft when doing lower wheel adjustments, i.e an east or a west loosened
to adjust for north or south.
Best done without blade tension also.
