hawks251
New member
Hi im having this very same issue did you manage to find a fix.
I have the same issue does someone have a solution. I wrote emails with Powermatic axminitor and tool france but no one can help me with the problem. Powermatic US said the display assembly has to be changed but they can not provide the part for the European versionDid anyone find a fix for this as i have the same issue thanks
Yes that is exactly what I need did you find the order number?Sounds like you need a circuit board I ordered one from Axminster tools exactly like the one below ill try and find the order number and send it over later costs around £135 I think
View attachment 189097View attachment 189098
Hope this helps
Yes thanks that helps a lot. I’ll ask them on Monday did you order the part a long time ago?Hope this helps
No ordered it in July 2024 and they had 3 in stock another member also bought one as she also had the same issue looks like a common issueYes thanks that helps a lot. I’ll ask them on Monday did you order the part a long time ago?
