Finally getting around to the installation. Now before anybody starts about the regs, I've spoken to two local installers and they ran!
It seems that my chimney was constructed by a left handed, one legged, Afghani jelly juggler!
So it's down to me!
The clay fire back is set back 5 inches, (125 mm) and the throat is restricted by a clay bar at the front that is angled at 45 degrees. This means that I will have to cut part of that away and/or the part of the back that slopes forward.
Beyond that there is no problem with space for a SS flue liner.
One installer proposed that a SS straight 90 degree flue pipe would reach in far enough if extended.
This worried me and I checked with a supplier and they agreed a 'no no' on the basis that fire starting could be difficult, proposing instead two 45 degree fittings, which at least makes sense.
Now, finally to my problem.
Flue liner suspended from cowl on top of the stack, no problem. What about the bottom where I convert from liner to SS or SE flue pipe? How do Support that lot?
Help!
Roy.
So it's down to me!
Help!
Roy.
