Lip sync
RogerS
20 Feb 2004
In the eternally wet North
Connecting up the PVR to the plasma screen has highlighted the problems with lip sync or rather the lack of lip sync. Then I started taking a hard look at the basic plasma screen and external AV amp combination and realised that there is a fundamental problem with the audio coming ahead of the image even on that combination.
So I reckon I need an audio delay of some sort between the plasma and the AV amp. I've discovered Felston but that's digital only ..and I don't have that connection between plasma and the AV amp...so any suggestions for an analogue audio delay unit?
Roger,
I had a similar problem with my Denon DVD player, Denon AV amp and Hitachi projector.
What AVamp are you using? The Denon amp (1906) has a digital audio delay that can be adjusted to bring them back in step and I believe most Dolby Digital compatible amps have a similar facilty.
Maybe yours AV amp can do the same.
If you need an external piece of kit, my system needed a delay of about 40mS so that should give some idea what area to be looking in.
Mike
Hi Mike
It's a Sony system and sadly no audio delay that I can locate. It has a digital input but the TV (Sony plasma) doesn't have a digital output. So that precludes any digital delay units such as the Felstom (??) unless I get an A/D converter and do it that way...which adds to the expense :cry:
Not sure why it is as noticeable as it is as I don't think the plasma has progressive scan which my quick research suggests is the reason behind much lip sync problems.
