gregmcateer
Thanks for the quick response, Jacob. Yes, the allback stuff
Nice. I have been using burnt sand mastic for years, i hate modern synthetic sealants.I have just read this thread and thought the document reference below might be of interest.
https://www.buildingconservation.com/articles/linseed-oil-paints/linseed-oil-paints.htm
Do you have any tips for me? I have a very old property and will be resealing the windows and doors to the brick work and want to try and use burnt sand and linseed oil.Nice. I have been using burnt sand mastic for years, i hate modern synthetic sealants.
Interesting about how paint fails and I've seen it often - waterlogged wood under pristine paint surface. Still blames the wood for paint failures. I blame the paint (alkyd) and my experience so far confirms this. Wood is just as good as it ever was OTBE.I have just read this thread and thought the document reference below might be of interest.
Whilst I agree generally with the rest of your post, in my experience, and I do tend to buy small, 500ml tins, even without added driers the linseed oil paint I buy skins over very quickly unless you manage to exclude the oxygen. You can lose quite a lot of the tin.In fact they have very long shelf life but will need a good stir if left for a year or more - I use a cheapo kitchen hand blender.
Not my experience at all. I exclude the oxygen by putting the lid back on tight - which also meant taking it off carefully in the first place to not damage the edge. Then shake it up to paint the seal inside.Whilst I agree generally with the rest of your post, in my experience, and I do tend to buy small, 500ml tins, even without added driers the linseed oil paint I buy skins over very quickly unless you manage to exclude the oxygen. You can lose quite a lot of the tin.
Is he still at it? I've emailed a couple of times with no reply and the web site is unchanged over a very long period.Some info here
https://www.linseedpaintcompany.co.uk/
I know this chap, I used to work at his cabinet-shop making arts&crafts furniture.
eg; Here's a nice big set of garage doors i made while there. Painted of course with the linseed oil paint.
Ross applied it. I just do the chopping of the wood bit.Is he still at it? I've emailed a couple of times with no reply and the web site is unchanged over a very long period.
How was the paint?
If the tin is half empty there is plenty of oxygen to start it setting up.Not my experience at all. I exclude the oxygen by putting the lid back on tight - which also meant taking it off carefully in the first place to not damage the edge. Then shake it up to paint the seal inside.
Not enough if the tin is well sealed. Even if there was, once it's skinned over the rest of it stays liquid.If the tin is half empty there is plenty of oxygen to start it setting up.
The chemistry I studied at degree level tells me otherwise, as does my past experience, but I use a different product.Not enough if the tin is well sealed.
Well there you have it!The chemistry I studied at degree level tells me otherwise, as does my past experience, but I use a different product.
I only have a phone with me at the moment, I'm away from home. I never did it for a living but was taught by a plasterer who worked for Historic Scotland and taught in the States too. As soon as I have a slightly bigger keyboard I'll put pen to paper. I bought, still buy, my burnt sand from Masonsmortar in Edinburgh. They may also have some info on their website.Do you have any tips for me? I have a very old property and will be resealing the windows and doors to the brick work and want to try and use burnt sand and linseed oil.
Blackfriar's Anti-mould. Then get some Zinser Cover Stain to seal it all in and apply a proper paint of your own choice. That is exactly what I did and very glad too. No mould.And now I'm proper confused !
I've used linseed oil paint on my porch and it was definitely easy to apply, BUT I've needed to clean and re apply in less than 5 years and now, about 2 years further on, it's faded and most annoyingly, mould keeps appearing.
Any advice on getting rid of the mould very very welcome!!
Yup...Mason's Mortar have an excellent website with a lot of information. It's very easy to apply but be prepared for some birds to take a linking to it.I only have a phone with me at the moment, I'm away from home. I never did it for a living but was taught by a plasterer who worked for Historic Scotland and taught in the States too. As soon as I have a slightly bigger keyboard I'll put pen to paper. I bought, still buy, my burnt sand from Masonsmortar in Edinburgh. They may also have some info on their website.
Jacob, as you're such an expert on everything, when are we going to see your fund of knowledge made available ?Interesting about how paint fails and I've seen it often - waterlogged wood under pristine paint surface. Still blames the wood for paint failures. I blame the paint (alkyd) and my experience so far confirms this. Wood is just as good as it ever was OTBE.
He's quite wrong about linseed oil paints being difficult to apply and labour intensive - quite the opposite it couldn't be easier, unless you make the mistake of trying to lay it on thick like alkyd paints, in which case it will run and skin over.
Also they don't have a tendency to skin in the can if you do the normal thing of shaking the tin after putting the lid on. In fact they have very long shelf life but will need a good stir if left for a year or more - I use a cheapo kitchen hand blender.
Using linseed paint is very different and if not appreciated then you will have problems.
I've never heard of burnt sand mastic! Sounds unusable anyway as it can't be painted?
Haven't had the mildew effect except once on a door but it was easy to wash off and looked good.
After 5 or more years linseed paint may look a bit dull or faded ("chalky") but the wood underneath will be in perfect condition and any minor failures easily remedied - putty being the most likely.
P.S. He's also wrong about "microporous" paints. It's just a sales slogan. All paints are "microporous" until you get to extremes using bitumen, gold leaf etc.
