Lichtenberg wood burning
Ozone created by the high voltages inside the TV used to be a smell many folk would recognise. I wonder if it still is
I can remember that smell from the high voltage test cells we had at EEV, the anode voltages for the valves under test were extremely high and for safety there was a crowbar across the busbar whenever the door was opened.
I had taken a couple of jolts and thought “ it’s only 12v
Vehicle electrical systems can deliver very high current if you short them out and more than enough to disolve any ring, watch or jewellery you might be wearing and the reason stuff like that was often not allowed to be worn. To this day I still do not wear a watch or any Jewellery.
Just wondering what precautions would be necessary to try this safely - for the benefit of those who might be thinking of trying it anyway. If the damp wood was placed on an insulating surface, perhaps glass or plastic, and the probes were attached before switching on, would that be adequate safety measures?
K
So many people who thought they knew what they were doing, and were doing it safely, have been electrocuted or at best, horribly maimed. Both the AWA in America and the AWGB (Association of Woodtruners of Great Britain advise against it, and no woodturning club in the UL permits demonstrations or experimentation with Fractal burning.
The practice uses high-voltage electricity to create lightning-like patterns. At least 33 people have died attempting it since 2016, according to the American Association of Woodturners. A Wisconsin couple was electrocuted attempting a popular but dangerous wood-burning technique, law enforcement officials said.
https://www.woodturner.org/Woodturn...fety-Fractal-Burning-Lichtenburg-Burning.aspx
Couple electrocuted after attempting viral wood-burning art technique
https://www.nbcnews.com/pop-culture...pting-viral-wood-burning-art-techni-rcna26109
Fractal burning, the controversial process for using high-voltage electricity to create designs in wood, has claimed the life of another man in Pennsylvania. A Lycoming County, Pennsylvania, man was pronounced dead Tuesday morning after an apparent electrocution accident while he burned designs into wood using the fractal design technique.
Sadly, since the AAW Board adopted its policy on fractal burning in 2017, there have been thirty-three reported deaths directly attributed to fractal burning, and an unknown number of injuries and close calls.
https://www.woodworkingnetwork.com/...l-accident-kills-43-year-old-pennsylvania-man
A MAN electrocuted himself while attempting a “dangerous” wood-burning technique in his garden workshop, an inquest heard. (June 2017):
Mark Sayer, 43, suffered a fatal 2,000-volt shock while using a high-voltage current to burn lightning-bolt patterns into a piece of wood with equipment he had built himself. He then fell to the floor where his clothing was ignited by an electric heater, causing a fire.
The inquest at Oxford Coroner’s Court on Thursday last week heard that he was likely to have been killed when he made contact with the equipment, which included jump cables, crocodile clips and a microwave transformer.
Mr Sayer was the estate manager for the Badgemore estate and lived in a cottage in the grounds with his wife Jade and their two sons, Hudson, seven, and Mackenzie, four.
https://www.henleystandard.co.uk/ne...le-burning-wood-in-workshop-inquest-told.html
Sadly, not only was his wife widowed and the children left fatherless, they lived in a tied cottage which went with her late husbands job, which they'd have to vacate.
Fractals starts at 7 mins into this video:
As to wearing rubber gloves, they'd need be insulated to 2,000 volts.
If part of your body (or even your clothing), touches the wood, (which will in fact be conductive due to the moisture content (otherwise it wouldn't burn), that would kill you. It isn't just the voltage, but the current: "It's the volts that jolts, but the mills that kills". (milliamps).
At least two of those electrocuted were electricians.
Seems to me that it's just one more way to prove Darwin's theory of the non-survival of the stupidest.
Could make your own headstone while at it ☹☠
Ignition on even quite ordinary cars now quite enough to kill you, let alone some of the stuff under the bonnet of an EV.
Now there's an idea, plug in a couple of cables into the ev car or wall charger, instant Fractal Burning device.
(PS: it's satire, before you all jump on me ☠️👻💀)
I fully agree with those who say it is dangerous, and I am not thinking of risking it myselsf but I was asking about ways of making it less risky for those who might still be tempted, despite the dangers. I am sure there will still be some of those out there.
K
K
Maybe a preliminary visit to your solicitor to make sure your will is in order.
