RogerS
I've moved along to the next room and have found a very thorny problem. The main beam (8" x 8" and 4m long) dips in the middle by about 20mm. This means that the upstairs floor is dished. Since I want to lay oak flooring up there etc I'd like to level out the floor to something approximating to level. The dip is just too noticeable to get away with.
The joints between joists and oak beam is as B in this thread . I originally thought that I could cut away the mortice in the main beam about 20mm vertically. That would let me lift the joist and I could pack it underneath with oak. However, the mortices are, very deep and go almost all the way through the main beam. So this approach will seriously compromise the strength of the main beam, I think.
So the only alternative that I can see is to plane the tops of the existing joists to an approximation of a straight edge. Then make 17 individually tapered pieces of green oak that will raise the floor level to the correct height. These would sit on top of the existing joists. Each tapered piece needs to be approx 20mm at one end and tapering down to 10mm at the other. Length is 2.3m. Bear in mind that these will all need to be tweaked. What's the best way to make these tapered pieces?
As an additional gotcha I'll need to somehow stain the green oak to approximate to the colour of the existing joists since our intention is to have these joists exposed downstairs.
As I write this I'm asking myself ...do the tapered pieces need to be green oak? Aesthetics say yes. Will the grain look radically different between the old and the new...even after staining?
Sorry to ramble on but I've been scratching my head for the best part of two days and discovered a whole new host of 'displacement activities' since I couldn't see how to resolve this problem.
