I have just one thing to rout yet - the backplate of the pickup switch needs a step. I'll get to it. I don't have a proper size template for this so I freehanded it and then cut to the edge on the other cavity with chisels.
Then, roundover rout on the back and copious sanding, which is something I never do outside of guitars. The interesting thing is limba planes cleanly, but 120 grit paper on a festool 125 and the wood is all hairy and torn. It's so soft.
The neck is getting closer to full size - I will install some kind of design at the top of the peghead other than just being round, but haven't decided yet. I need to thickness the peghead a bit further and install a rosewood overlay to match the guitar top. to do that accurately, I think I will need to install the fingerboard first, and that's OK as I'd prefer to finish the rest of the neck shaving and measurements with the fingerboard installed, too. So it'll be a little bit before I get the fingerboard installed and back on this.
I turned the edges of the peghead template in toward the center a little and reset the gibson-ish lines so that the third and fourth strings will be just a little closer to a straight string pull. I think I will make an inlay in the peghead with my initials, but in celluloid, and will do that I don't know when - probably before the neck is installed would be smart.
