sneaking time here and there....
More push back and hollowing of the raised field at the edges before binding - on the fence about coloring the limba. If not, I think tortoise is a good binding choice instead of ivoroid. coloring the limba is a bit of a pain as the dyes that I have don't make it look that great and I know it looks wonderful by itself with buttonlac (but against the rosewood and the maple neck, maybe some clashing.
Will make some kind of travishing tool pair or pullable shave as most of this has been spokeshave and then card scraper. Evening out the side height and then adding binding on the top will help with the carve, but pushing the carve back a bit further before fairing the curves into the top would also make it easier to add the binding.
Pickup cavities just drilled and roughed with a chisel so far. Will finish them to size and then either gouge/chisel the inside or use a trim router to match the tip side of the cavity and leave a clean bottom - not sure yet. Looking at pickup cavities is a popular thing to determine workmanship in a guitar, but I can't get motivated about it being important.
