user 40242
- Joined
- 5 Oct 2022
- Messages
- 6
- Reaction score
- 1
Spear & Jackson
Does a horse pull the cart or push it!the pushers and the pullers
That could be something of a red herring, because most dovetails can be cut most efficiently with a tenon saw. The so-called dovetail saw has tiny fiddly teeth that are a pain to sharpen and because they're so small take forever to make a cut. The larger tenon saw, with bigger teeth and a wider set, is actually easier to control. So I say tenon saw.a decent western dovetail saw
It pushes it when it's being backed. Whoah.Does a horse pull the cart or push it!
15 tpi is good for thin drawer sides ( say 12mm softwood) and 8" DT saw better IMHO.That could be something of a red herring, because most dovetails can be cut most efficiently with a tenon saw. The so-called dovetail saw has tiny fiddly teeth that are a pain to sharpen and because they're so small take forever to make a cut. The larger tenon saw, with bigger teeth and a wider set, is actually easier to control. So I say tenon saw.
you're going to have to buy two saws! Sigh.
yes I agree, my main 'dovetail' saw is actually a 14tpi 10 inch tenon saw, spear and jackson, cost almost nothing second hand on ebay, it needed sharpening up but other than that it's been a great saw it's nice to have a finer dovetail saw but not really critical, you can also use it for tenons too so very useful.That could be something of a red herring, because most dovetails can be cut most efficiently with a tenon saw. The so-called dovetail saw has tiny fiddly teeth that are a pain to sharpen and because they're so small take forever to make a cut. The larger tenon saw, with bigger teeth and a wider set, is actually easier to control. So I say tenon saw.
