Hi,
During the last 60 years I've changed many types of bearings but I thought it might be worthwhile adding a few details of how easy it actually is to change headstock bearings. I'll try to put this thread together as I go along because otherwise I could get bogged down adding all the images. I like other mechanical engineers change machine bearings without having to give the job much thought.
Cleanliness; patience and gentleness are needed; dirt of any kind and bearings are enemies; it's no good dashing in just trying to pull everything apart because a mistake could prove costly; gentleness is needed because using excessive force could render the lathe as scrap; cast iron can be fractured/broken.
The first lathe is a very easy one it being a Record Power DML24" I've owned this wonderful small lathe for over 30 years and a few years ago it was not running as smoothly as it used to run so no problem just replace the headstock bearings so here it is possibly not in the correct order otherwise I'll be here all day;
I've always liked this DML it being a special present from my lovely wife all those years ago when we had little spare money; it was bought new from Tabwell tools in Bakewell as a Christmas present to me costing £199.00 having no sooner got it home Record slashed the price to £99.00 which really did infuriate me but this aside it's still a lovely lathe.
The headstock mandrel is removed towards the tailstock; I screwed in a set screw ensuring it was well home as seen top; the bottom is just the motor plate. See lower because the mandrel isn't ready yet to be removed. When everything is ready a hammer is used to tap the mandrel free by hitting the head of the set screw; this will eject the mandrel and main bearing but leave the outboard bearing still within the headstock.
The mandrel fully removed without causing damage.
Here's the mandrel but please note the small machined flat top right; this is very very important indeed because it's the section where the pulleys are installed and a grub screw bears down tightly on this flat; to attempt to drift the mandrel out without first removing the grub screw could break the casting so please be warned.
The main bearing fitted from the factory; NTN is a decent make of bearing; there are many bearing manufacturers making this size; I tend to use SKF bearings finding these reliable and reasonably priced but for a novice don't think bearings are very expensive when in fact it might surprise you; on eBay an SKF double metal shielded 6204 can be had for as little as £3.50 including postage the outboard bearing will be even cheaper so a pair of bearings could only cost around £7. For this lathe rubber or metal shielded bearings could be used.
Gently withdrawing the outboard bearing using a spacer the spacer needs to have an inner diameter larger than the outer diameter of the bearing this allows the bearing to be pulled into the spacer. Whilst removing any bearing if it locks up never ever apply undue force but find out the reason.
The three step Poly V pulley; as I said earlier regarding the small machined flat on the mandrel here's the reason for it; the grub screw which must be removed; screw it well out so that it no longer binds; on many lathes there could be two grub screws and these into indents but on the DML it's straightforward enough; if in doubt completely remove the grub screw but do not lose it. A set of Allen keys will be needed but a set doesn't cost much; I used to buy sets from Poundland. It's worth noting for a novice the set screw unscrews anti clockwise. be careful to reinstall the pulleys the correct way round.
The clean bearing housing; bearing housing must be very clean indeed and bearings too kept away from dirt.
The drive belt and guess a very common mistake that can be made; yes to fully assemble the lathe with new bearings thining what a good job I've made of this only to find the drive belt hasn't been installed; if new bearings are being installed then also install a new drive belt these don't cost much and are available from many places even eBay.
The new SKF bearings only costing around £7; the large bearing is the main bearing the small bearing the outboard bearing but it does depend on the type of headstock being worked upon; these are classed as double metal shielded.
More yet to follow so please bear with me.
Kind regards, Colin.
