Mr Ed
I've done an operation similar to this making heads for thumbscrews, where I wanted to make a batch all in one go. Basically used the method Jason describes, the only difference being that I used a parting off tool to set out the wheel thicknesses cutting part way through and then a V shaped cutter to go into the gap left to make the chamfer, prior to finishing off the parting. I have a quick change tool holder so this method is no hassle, it would be a bit more inconvenient without. Jasons suggestion of a combined tool is a good one, but it can be done with individual cutters if needed.
On the subject of cutters, it is easier than you think to grind your own. I am new to this type of lathe work and got a box of toolsteel blanks with my second hand lathe when I bought it. Consequently I had a go at grinding cutters following instructions off the net and got good results almost straight away.
I found this website with some initial instructions on lathework generally quite helpful to begin with
http://www.americanmachinetools.com/how ... _lathe.htm
couldn't find a UK site with similar detail but that doesn't really matter.
Cheers, Ed
Cheers, Ed
