RichardG
If at first you don’t succeed have a cup of tea.
I think you have to accept that turning generates a lot of waste and be prepared to clean up afterwards, just try and make the area as easy as possible to sweep up. You could try and capture the shavings but you'll need a HVLP type extractor, that numatic will fill its bag in minutes. The only time I use dust extraction is for sanding, the numatic will be fine fir that, but I do wear a mask all the time I'm at the lathe.
