sploo
Somewhat extinguished member
I've got a Colchester Chipmaster (D1-3 spindle nose) and I'm slowly getting myself set up with accessories for work holding, as well as checking the (new to me) lathe over.
The external taper of the spindle nose clocks in at about 5 ten-thou (0.014mm) total indicated runout; as least based on my shonky skills with an indicator. The face of the spindle nose is less than 4 ten-thou (0.01mm). I'm assuming that's OK.
The D1-3 dog plate and 5" chuck on a backplate that came with the lathe, as well as a Pratt 6" chuck on a new D1-3 backplate I bought from Colchester (D1-3 Spindle Nose adaptor for Pratt Burnerd 160mm 3 Jaw Chuck - Colchester Machine Tool Solutions) are perfect in terms of fit, and what-I-understand-to-be acceptable runout.
However, I bought a D1-3 mount ER40 collet chuck and it doesn't sit flat on the spindle nose. It's so far out that I could get a 7 thou feeler gauge in between the back of the chuck plate and the face of the spindle (at one point). Assuming it was just a poorly machined example I sent it back.
I've just taken delivery of a D1-3 backplate from Warco, and it too has a problem. It's more subtle, but I can slip a 1.5 thou (0.038mm) feeler gauge between the rear of the plate and the spindle nose (see the photo below) for maybe 1/6 of the circumference around the spindle. No amount of adjusting D1-3 camlock pins or trying different orientations will fix it.
I tried a bit of engineer's blue on the taper in the backplate and it doesn't seem to be touching the spindle nose taper all the way round.
Given that the spindle nose clocks in well (5 ten-thou runout), and the spindle face appears flat to 4 ten-thou, I assume it must be the adaptor?
