Eric The Viking":1fpnce50 said:
They do look good.
I have a couple of questions though: I see the rebates for the glass panels, but how are you intending to fix them and the fabric in place? Also, are they sat on carefully-levelled and sturdy plinths, or did you use kitchen-style levelling feet, or something else?
I intend to silicone the glass is along with some of
THESE just in case.
The fabric will be on rails like
THESE fixed to the insides of the doors.
I made a number of cross shaped plinths and fixed to the underside of the unit, the front plinth went on after the unit was installed so I could get underneath and pack some of them up were the floor was uneven, and god was it uneven its a really old house.
I've used the levelling feet on a previous project that was a lot smaller than these and they struggled with the weight of that so I wouldn't use them for wardrobes.
The crown mouldings look like they're made up in sections. Were you able to rout all the upper and lower profiles, or did you have to use a spindle/saw table? My crown mouldings will have to be fairly substantial (both cupboards and room are tall), and I haven't yet got a profile I'm both happy with and can actually make!
I must admit I cheated with the crown moulding, I did think about making it myself but I didn't have the time so I bought some, the company is called Dresser Mouldings from Rochdale I can't recommend them enough, decent price, really cheap postage considering they came in 3.6m lengths and really helpful when I rang them up.
MartinCox":1fpnce50 said:
Great job. I have a question about the drawer structure as I am about to make a load for myself. What material, what thicknesses, type of joint and what runners. In fact, everything about the drawers! Thanks
They are really basic drawers just butt jointed and screwed together but I used the domino jointer to aid alignment and it adds a little extra strength. I would have used a more pleasing joint if they were made of fancier materials but as its all going to be painted I could get away with filling the screw holes.
The front, back and sides of each drawer is 18mm MDF and the drawer bottoms are 6mm MDF which sit in a 9mm deep groove all round the inside of the drawer.
The runners are
THESE, very easy to fit and have a nice smooth action, a bit of a warning though the carcasses have to be 100% BANG ON SQUARE otherwise they bind badly and miss the pins on the back for the soft close mechanism. I know this because one of the uprights was a tiny fraction out of square and I had to pack out the backs of the runners to pull them square.
I really enjoy making and fitting drawers theres something really satisfying when they glide shut and the soft close grabs perfectly.
Thanks for the kind comments
