Phil Pascoe
Jacob":1gca9d2c said:I think it'd be a problem. A well makes it easy to just whip off a few mm to bring the beam or beams into line. If I was going to join massive timbers like Mr Maguire's I'd do it the easy way with steel rod through with nuts on threaded ends. You could then tighten/loosen or separate the pieces for planing, if necessary.DTR":1gca9d2c said:Slightly off-topic, but a related question: In a bench with an underframe supporting the top (for example, Chris Schwarz's "Nicholson" and I suspect Richard Maguire's "Empire"), how is movement of the top dealt with? In my own bench the top is fixed at the front, and any movement is absorbed by the tool well.
That was my thought - I'd just run stainless threaded bar through, and save an awful lot of work!
Phil.
