dvddvd
Just bought a Lamello classic x biscuit jointer.
If you rest the base on a table the measurement from table to centre of cutter is 10mm. Same with the flip down fence, from fence to middle of cutter is 10mm.
I would of thought most people use them on 18mm boards so why didn't they make the measurement 9mm?
I know you can put on the 90 degree fence and make the top measurement 9mm, but the jointer won't fit in the box with it attached so for quick and easy biscuits, would it not been easier to make it 18mm from flip down fence to table not 20mm?
