Dhenry, Thanks for the link.
I found a feed belt for the planer thicknesser, (530mm x 6mm), and the smaller of the saw belt's , which is the slow speed one (710mm x 15mm) Which, strangely enough, are the very ones I've been looking for, as the saw belt is stretched, as I imagine the previous owner left the belt on tension for years, and the planer feed belt is starting to look raggedy.
At £25.00 +£10 post not cheap but I rather hope that as they appear to be the right ones, possible problem solved , as the machine is useless without them!
The problem I have found here in trying to get belts made, is they want my belt as a pattern in composition, and if the
belt gets lost or mislaid, then I'm I really would be in trouble.
I'll let you know how it all goes and if 710mm, and 530mm are the same in french, as in english!
Anyone wanting belts for french machines, try here,----
http://www.ebay.co.uk/itm/Courroie-plat ... 5645ab7230
Regards Rodders
