woodshavings
I installed halogen downlighters in the kitchen a few months ago. I used the Screwfix kits - 3 off 20 watt fittings plus electronic transformer for £10.
I have 14 lamps, split between the two original lighting circuits, a dual dimmer replacing the original switch. The dimmer works fine.
The lamp fittings fit a 68 mm hole. The transformers will also fit through this hole size. I could not get easy access to the floorboards above the kitchen ceiling so I cut slots across the floor joists from the ceiling side where the low voltage connecting cables needed to cross the joists, with a simple replastering job over these areas when finished.
In 3 months, I have had one bulb failure. The lamps "soft start" because of the dimmer and are usually run just below full power. I think this prolongs the bulb life. The 20 watt bulbs do not generate excessive heat - they sit in the "free air" in the ceiling space and show no signs of overheating.
HTH
HTH
