Dibs-h
petermillard":3vowaf44 said:Triggaaar":3vowaf44 said:I'll virtually guarantee that they won't be the last chisels you buy.
Cheers, Pete.
Yep - so true, but true of almost all hand tools me thinks.
Cheers, Pete.
And I appreciate all the advice - it's not like I'm only buying chisels here.petermillard":emuk0pgi said:Dude, you've had lots of advice, lots of opinions, on this thread and all the others
Whatever you end up with, though, I'll virtually guarantee that they won't be the last chisels you buy.
Aye, but I was hoping not to be buying more chisels for a while, this spending spree has got to be kept under some sort of control.Dibs-h":emuk0pgi said:Yep - so true, but true of almost all hand tools me thinks.
Triggaaar":24g7onl6 said:Whatever you end up with, though, I'll virtually guarantee that they won't be the last chisels you buy.Aye, but I was hoping not to be buying more chisels for a while, this spending spree has got to be kept under some sort of control.Dibs-h":24g7onl6 said:Yep - so true, but true of almost all hand tools me thinks.
I'd leave the chisels for now - just sharpen up the ones you have. I'd much rather "ruin" crap chisels learning how to sharpen than ruin some expensive ones.
And I thought I was the only one to do that. I did manage to smuggle a table saw in, the old one out and got away with it. swmbo couldn't tell the difference between them - to her it had a blade so was the same thingOr involves smuggling tools into the house and hiding them. :wink:
jlawrence":2t0t0puc said:And I thought I was the only one to do that. I did manage to smuggle a table saw in, the old one out and got away with it. s
Good point. There are those sharpening sheets, or maybe a faithful 4 sided stone (or is that not good enough?) and I'll practice on my old chisels.Dibs-h":2o2nts3j said:I'd much rather "ruin" crap chisels learning how to sharpen than ruin some expensive ones.
A bit of both really. Not got much money at the moment, so have to justify it to me too. I can justify I fair bit though, since it's cheaper than getting a chippie to do it."Under control" - is that SWIMBO terminology? :wink: Ask the chaps on here - the only time they'd mention that in regard to spending is in a converstion with Wifey person.
Those exact sentances are probably being used between our other halves on the subject of clothes.jlawrence":2o2nts3j said:I think the trick is to get rid of the boxes asap before they get noticed.
It's a shame that they don't always understand the need for something new
Triggaaar":3otgcz29 said:I'm now concerned about using the chisels. I didn't want to spend £50 on some temporary chisels (already have some drapers that do that job), if they're not going to last I'd rather spend more.
Dibs-h":flok0m50 said:jlawrence":flok0m50 said:Top tip - don't stash them all in the same place - she's bound to explode if she saw them all together. One here, another there - preferably a mix of upstairs and downstairs - you'll be fine. :wink:.
Unfortunately, yes, other brands can suffer from this. Even the mighty Festool (which start quite tight in my experience) which uses TWO connector bars isn't immune.Triggaaar":3cidtrp6 said:This maybe also happen with the other brands, I don't know.
Would it, though? And does it really matter that much? In use you'll end up dinging the corners and possibly even chew off a bit of edge here and there over time. Sorry if you find that depressing, but it's what happens even with careful useTriggaaar":3cidtrp6 said:And secondly, when you tighten the screws on the bar with an alan key, you can easily dent the aluminium rail by over-tightening them. All that's needed to fix this issue (IMO) is to have the screws made for a smaller alan key, which will encourage users to use less force when tightening them.
But if you start out with crap chisels (i.e. ones which won't take/hold an edge) how will you know when you've "mastered" the art of sharpening? BTW the Faithfull cheapo 4-sider is perfectly good for chisels, and really cheapTriggaaar":3cidtrp6 said:Good point. There are those sharpening sheets, or maybe a faithful 4 sided stone (or is that not good enough?) and I'll practice on my old chisels.Dibs-h":3cidtrp6 said:I'd much rather "ruin" crap chisels learning how to sharpen than ruin some expensive ones.
A bit difficult when you go out shopping on a Friday evening and have to unload the boot of the car first! She still doesn't believe me when I tell her that "I need it for the job, love" :roll:jlawrence":3cidtrp6 said:I think the trick is to get rid of the boxes asap before they get noticed.
FatFreddysCat":28eojm5w said:But if you start out with crap chisels (i.e. ones which won't take/hold an edge) how will you know when you've "mastered" the art of sharpening? BTW the Faithfull cheapo 4-sider is perfectly good for chisels, and really cheap
I guess I'll just stick to using a straight edge to check the join, no biggie, thanks.FatFreddysCat":2j2gwzci said:Unfortunately, yes, other brands can suffer from this. Even the mighty Festool (which start quite tight in my experience) which uses TWO connector bars isn't immune.
Fair point, just didn't seem to be a good thing when I noticed it.Would it, though? And does it really matter that much? In use you'll end up dinging the corners and possibly even chew off a bit of edge here and there over time.
Triggaaar":1k4gdij4 said:It's a bit tricky to base a decision on one review...
...does anyone know if dust extraction isn't an option without buying extra parts?
Triggaaar":3qhkf0mr said:Those exact sentances are probably being used between our other halves on the subject of clothes.jlawrence":3qhkf0mr said:I think the trick is to get rid of the boxes asap before they get noticed.
I've found somewhere locally that has the DeWalt on display, so I'm off to check it tomorrow or Sat.petermillard":tv1e3lt4 said:When I was looking for my first serious mitre saw I scoured the reviews religiously and had my heart set on one particular model; purely by chance I got my hands on one at a trade show and hated it; everything about it was wrong for me - the handle position, the trigger, the slide action was nasty, it was awkward to carry. I bought something else that 'felt' right and I'm still using it ~10 years on.
Thanks, those kits aren't too much, and obviously you can buy the one that fits your extraxtor. It's then a question of whether these kits take the dust extraction beyond the other saws (which would be nice) or if the kit is required just to bring the standard to the same point.Looking at the pictures & videos, the 777 seems to have an extraction port on the blade guard as well as the usual one immediately behind the blade; judging by the contents of the DeWalt Dust Kits - here and here - there may well be a third port to connect to as well, hence the need for a 'kit' rather than just plugging in a vac. Nothing to stop you just plugging in a vac of course, but obviously you're only extracting from a single port...
I agree, nice to have some lovely kitchen knives. She's one of us!big soft moose":tv1e3lt4 said:my other half just spent over a hundred notes on kitchen knives , apparently this expenditure was "necessary" because "the cheap ones dont last"
.... care to guess what my justification for buying a clifton no.6 is going to be
big soft moose":3etxahc9 said:my other half just spent over a hundred notes on kitchen knives , apparently this expenditure was "necessary" because "the cheap ones dont last" and " these are made from better quality steel so stay sharp for longer" I think she was expecting an argument but i just smiled and nodded....
D
