tombo
a big version of rob's avatar is now on the lee valley web site, pull shave looks fun to use but i am a long way from trying to build a chair.
Tom
Tom
tombo":3nae9sve said:a big version of rob's avatar is now on the lee valley web site, pull shave looks fun to use but i am a long way from trying to build a chair.
Tom
bugbear":1096ng3t said:tombo":1096ng3t said:a big version of rob's avatar is now on the lee valley web site, pull shave looks fun to use but i am a long way from trying to build a chair.
Tom
Looks like LV are going for a full set o' chair tools.
Even a chair scraper
http://www.leevalley.com/wood/page.aspx ... at=51&ap=1
Although of course a shop made one is nicer, more personal and cheaper:
http://www.cornishworkshop.co.uk/scraper.html
Bit like winding sticks
BugBear
Philly, tell me you didn't... :shock: #-oPhilly":3b5xw850 said:I was sold with the way they slide into each other. :roll:
Alf":34rfi0mx said:Philly, tell me you didn't... :shock: #-oPhilly":34rfi0mx said:I was sold with the way they slide into each other. :roll:
dchenard":2yol4hw0 said:Cheaper, that's only if you don't value your time... I do for mine, so I bought the LV sticks. You wouldnt believe who I had to convince that it was a good buy... :shock:
Yeah, yeah... Got the same problem myself at the mo'; only £40 to go... Must not buy classic reprints, must not buy classic reprints, must not buy classic reprints 8-[Philly":2f2ejkzj said:Alf,
Well you see, I needed to make the "free postage" limit from Axminster......
Ducking and running,
Philly
Rob Lee":2l179495 said:Alf":2l179495 said:Philly, tell me you didn't... :shock: #-oPhilly":2l179495 said:I was sold with the way they slide into each other. :roll:
Don't blame me... I tried tried talking all of you out of it...
DC was Christmas eve, if I recall correctly...
Rob
Paul Kierstead":b7tyzhau said:dchenard":b7tyzhau said:Cheaper, that's only if you don't value your time... I do for mine, so I bought the LV sticks. You wouldnt believe who I had to convince that it was a good buy... :shock:
Ah, c'mon, it takes longer to drive to the store and back then it takes to make a set. Set TS fence. Saw. Saw. Put togather in vise. Plane togather. Done. What, 3 min? If you want to be fancy, drill a shallow hole and place in a magnet so they stay togather. Another couple of minutes.
Don't think that feature was designed in, was it... :-kdchenard":2zp9hnfj said:unless one uses his/her sticks to pull nails and open paint cans :shock:
That's very true. With good tools I found I could concentrate on making a perfect skew dovetail and have over-confidence enough left over to totally fail to allow for the compund angle involved. #-o With poor tools I'd have probably had a badly fitting poorly executed joint. But seriously, it is true. Being able to rely on the tools is a big, big help.dchenard":2zp9hnfj said:Not having to worry about your tools is worth a lot. It keeps one concentrated on the job at hand, without interruptions that can break your concentration and lead to mistakes...
Alf":3bovlrgq said:Don't think that feature was designed in, was it... :-kdchenard":3bovlrgq said:unless one uses his/her sticks to pull nails and open paint cans :shock:
That's very true. With good tools I found I could concentrate on making a perfect skew dovetail and have over-confidence enough left over to totally fail to allow for the compund angle involved. #-o With poor tools I'd have probably had a badly fitting poorly executed joint. But seriously, it is true. Being able to rely on the tools is a big, big help.dchenard":3bovlrgq said:Not having to worry about your tools is worth a lot. It keeps one concentrated on the job at hand, without interruptions that can break your concentration and lead to mistakes...
Cheers Alf
Alf":jkhfydsl said:In the "post a reply window", on the left hit "View more Emoticons" and a pop-up window should open with a selection for your emotion-conveying pleasure. You may need to scroll the window, or better still enlarge it.
Cheers, Alf
Smilie junkie 8-[
dchenard":8xlastwk said:With the Veritas set, they're true from the beginning, and five, ten years down the road they will still be true, unless one uses his/her sticks to pull nails and open paint cans :shock:
DC
Alf":2kt8k9d8 said:In the "post a reply window", on the left hit "View more Emoticons" and a pop-up window should open with a selection for your emotion-conveying pleasure. You may need to scroll the window, or better still enlarge it.
Cheers, Alf
Smilie junkie 8-[
Paul Kierstead":kgrk9b1x said:dchenard":kgrk9b1x said:With the Veritas set, they're true from the beginning, and five, ten years down the road they will still be true, unless one uses his/her sticks to pull nails and open paint cans :shock:
DC
Ah, I think you are working hard at justification. Pretty much every tool in the shop needs checking and tweaking, even straight-edges. It takes literally seconds (like 5) to check, and very few more to fix. Now if ya like 'em, that is ok, but to say they save time ... well, c'mon. Seriously, there is no simpler tool in the shop, to make or maintain. Even a glue caul can be more difficult then a pair of winding sticks if you want one with a nice bow.
