marcros":3g4fsga8 said:Not sure on those. I got a small one from eBay which I find invaluable. It is similar to http://bit.ly/1d4BS6i (if link works) but didn't have the card and was a couple of quid cheaper. I seem to think it was from eBay USA.
It is really handy for small pieces and machine fence setting.
Once you have one decent one you can take it to wherever to check the next one you buy. A 6" one is also handy.
The ones you show will probably be fine. Alternatively look at what axminster offer. Engineers squares seem to be better than carpenters ones. Even the b grade engineering ones will be fine for wood.
RB61":309qg8dc said:marcros":309qg8dc said:Not sure on those. I got a small one from eBay which I find invaluable. It is similar to http://bit.ly/1d4BS6i (if link works) but didn't have the card and was a couple of quid cheaper. I seem to think it was from eBay USA.
Thanks for the link. I have been looking for a double square also.
Since I am in the US, I assume Axminster may be too costly due to shipping, but I will look.
David C":2m6o1eee said:Peter,
Where do you get your Fischer squares from please?
David
Cheshirechappie":3n0mllcm said:Just in case anybody is slightly confused, the firm of Joseph Marples is NOT the same as the William Marples the prolific chisel and plane blade maker, now sadly absorbed into the Irwin Tool empire. Joseph Marples have been independent since 1840, and have always specialised in marking-out tools for woodworkers. Their website is http://www.marples.co.uk/
The squares shown in the photo above are from their premium 'Trial 1' range, except for the little 3". Their website states that their squares are made to slightly better accuracy than stated in BS3322, and are square on both inside and outside to better than 0.01mm per 10mm of blade length, so a 6" square should be less than 0.15mm (6 thousands of an inch) out of square over it's full blade length. (I think I'm right in saying that BS3322 only calls for squareness on the outside of the blade, and sets no standard for the inside. Marples clearly do better than this.)
I'd say they should serve well - but despite the manufacturer's assurances, it would pay to check for squareness when you first receive the tool, and return for replacement if it's off the mark. The easy way to check is to find a nice clean board, joint an edge straight, then set the square against it, and with a DEAD SHARP pencil, strike a line on the board on both the inside and outside of the blade, being careful to keep the pencil at the same attitude to wood and blade for the full stroke. Then flip the square over, and carefully compare the marked lines to the edges that marked them. They should be bob on.
The squares I find most useful are a Marples 6" I use for 'near enough' jobs such as setting out rough stock, a little 2" engineer's square for laying out joints and fiddly work, and a 12" Marples for bigger stuff. I need to add a really big square for carcase work, but I think I'll make one (about 24" or a bit bigger) from some nice, stable hardwood, and use it only with pencils and for checking. A steel roofing square world be an alternative, but I've heard too many tales of gross out-of-squareness from budget ones, and I'm far too tight to shell out for a premium one.
For anybody thinking about an engineer's square, Moore and Wright, Mitutoyo, Starrett and Browne and Sharp are considered the 'premium' makers. The Fisher squares mentioned above will be perfectly satisfactory for even fine cabinet work, but do be a tad careful with budget Ebay ones - they may be fine, but check on receipt.
The remaining tool manufacturers on Sheffield - Joseph Marples, Thomas Flinn, Clifton, Crown, Henry Taylor, Footprint all make mostly traditional tools. Well, if you exclude the oddball Crown multi-angle square thingy ! I suspect that they have done their market research and have chosen to cater for those wanting tools like they used to be. The alternative puts you in competition with lots of newfangled - and more mass produced stuff.condeesteso":1lm4r76o said:Re J Marples, I greatly respect their continued independence and the tools are a million miles from the Irwin Marples offerings - but I would personally like to see them investing (I mean effort, not simply capital) in evolution - most of the marking tools they offer have not changed in many decades whilst newer competitors have been evolving and innovating. You don't have to like the 'new fangled' variants, but what others have been doing is taking sales from J Marples surely? They could do both - keep the Trail One series for traditional quality, and develop some newer variants. They are one of the very few remaining toolmakers in Sheffield - I would like to think they will be thriving decades from now.
