Wow. Just wow. At least no one mentioned sharpening!!!
Do you actually do much woodwork?
The thing with communal set squares as supplied by FE colleges and similar is that they're generally no more than slightly interesting pieces of wood and metal with neither edge of the blade at a right angle to the stock.The other thing to remember is that when using college squares which weren't always treated with respect by everyone, it was a safer bet to use the inside faces which were a little less prone to being knocked or dented.
Personally I don't think I would have been happy being taught the "incorrect" way to use a square. The maker of these squares recommend and guarantee two faces, both on the inside.![]()
Patience, its still fairly early in the morning...Wow. Just wow. At least no one mentioned sharpening!!!![]()
Really! A finer example of dogmatism than your post i have rarely seen!!!Dogmatic as usual Jacob
and you got a sharpening dig in as well, brilliant, you never let me me down
Another thing I was taught Jacob ( I was not ill advised) was to put your knife on or in the mark first and then move your square to it, you then don't need to see the line. I don't have a copy of the manufacturer's literature to hand, the catalogue blurb which described the squares I purchased as an apprentice certainly refered to the accurate faces. The rest of your assumptions about my training are also incorrect.
You're like a dog with a bone now and its getting boring, you do the same thing everytime you are challenged about anything, you cherry pick part of a reply, taking it out of context and away you go.
As I said previously, read the posts, you are wrong.
This is nonsense. If you knock the outside edge then the inside edge will move with it and be equally out of line. They are connected by the metal in between. Have another look at one!....
Well you were! I hope you are not too disappointed, it's obviously a bit of a shock! Maybe take the day off and take it easy?Personally I don't think I would have been happy being taught the "incorrect" way to use a square.
No they don't!*The maker of these squares recommend and guarantee two faces, both on the inside.![]()
The thing is Richard I rarely if ever use a traditional carpenters square these days, I prefer engineers squares which are guaranteed accurate inside and out, at least the ones I buy are.The thing with communal set squares as supplied by FE colleges and similar is that they're generally no more than slightly interesting pieces of wood and metal with neither edge of the blade at a right angle to the stock.
As to being taught use of the square I'd guess if you'd been taught to use it the way Jacob, myself, and probably 98% of all woodworkers use a square to square lines across a piece or pieces of wood ganged together you would never have questioned whether you were happy about it, or not.
Certainly, I find how you were taught and how you continue to use a set square by habitually striking a line using the inside edge of the blade at least mostly awkward and rather odd. There are times when I find it's helpful or even best to use the inside edge of the square's blade to strike a line against a piece of wood, but for me that form usage is very rare indeed.
Anyway, I'm out of this thread: there's been more than enough nit-picking nonsense said in it for such a mundane topic. Slainte.
Well you were! I hope you are not too disappointed, it must be a shock!
No they don't!
Anyway thats enough fun for today - I've got better things to do.
Good for you.Really! A finer example of dogmatism than your post i have rarely seen!!!![]()
Oh no, he's slipped his leash, there's no stopping him nowThis is nonsense. If you knock the outside edge then the inside edge will move with it and be equally out of line. They are connected by the metal in between. Have another look at one!
No they don't!
Jacob did mention it but I think we got away with it.Wow. Just wow. At least no one mentioned sharpening!!!![]()
Well yes. Something of the Monty Python dead parrot sketch about it.At least everyone is in agreement that my square is trashed and should be replaced. I could frame it though as a momento to my most controversial post from what I thought was a reasonably mundane question
I said I was out of this thread, and I did mean it. But I'm jumping back in just this once, Jacob to say that I think you're being a bit mean with that post. You'd made your point more than adequately in earlier posts and there was really no need to come come up with the "Mark Wrong" shot and the rest of the digs there to, presumably, have a bit of a go at mark w.Well yes. Something of the Monty Python dead parrot sketch about it.
The patronising tone a bit tedious and the quasi religious delusion of "correctness" rather strange.
Have to ask, does anybody else use the "Mark Wrong" method? I sense no takers.
Don't all answer at once!
It's the normal trad way of laying out marks for a project, particularly if simply rectangular like most joinery and furniture. Basically a full size sectional drawing on a board, on to which the components are laid and stacked, with the marks taken off directly, with a pencil and a set square. First they need face and edge marks so that they can be laid up in opposite pairs, to avoid getting all left handers etc etcI hesitate to ask, but what is the 'rod' method that you refer to Jacob? Thanks.
Oh well, he was being a bit belligerent! And relentless - he was accusing you too of nit picking and being ignorant of his imaginary "rules"!I said I was out of this thread, and I did mean it. But I'm jumping back in just this once, Jacob to say that I think you're being a bit mean with that post. You'd made your point more than adequately in earlier posts and there was really no need to come come up with the "Mark Wrong" shot and the rest of the digs there to, presumably, have a bit of a go at mark w.
Now, I really am out of here. Slainte.
It does get used a lot when laying out kit car chassies rails.It's the normal trad way of laying out marks for a project, particularly if simply rectangular like most joinery and furniture. Basically a full size sectional drawing on a board, on to which the components are laid and stacked, with the marks taken off directly, with a pencil and a set square. First they need face and edge marks so that they can be laid up in opposite pairs, to avoid getting all left handers etc etc
Once the rod is completed all marks are taken from it directly, or measurements for cutting lists etc, no calculating required.
Once the marks are on one side or edge of the component they are then taken around with a marking square (using the outside edge!) and other gauge marks etc added.
It's very fast and can be very accurate, eliminating errors.
We had a good example here although of an unusual project which also included curves. https://www.ukworkshop.co.uk/threads/building-bridges.147261/
It features in all the old books to a large extent, but not often the new ones. Another forgotten art!
