swagman":3fz738jl said:
the cap iron set should be slightly larger than the thickest shaving you'll take with a given set.
In acknowledging DWs as sound advise; I see no real benefit in cambering the CB.
Stewie;
Thank you Stewie, that is precisely it. There's no benefit, but there is the potential to cause a problem. As the edges of a cambered shaving thin out, it's sub optimal to have the cap iron progressing back from the edge at the same distance as the thicker middle of the shaving/iron.
I suspect it would be monstrously difficult to find a piece of wood that tore out on one and not the other, though.
The bigger probably is the potential for having corners that come up from the iron, depending on the type of cap.
