andrewm
Need to fit a kitchen worktop. Using a mason's mitre, biscuits and worktop joining bolts but how do you ensure that the two surfaces are level? Even with biscuits there is a bit of play and even ten thou difference is going to be obvious if you run you fingers over the join.
I had thought about using a couple of cauls to clamp along the length but the long piece runs the full width of the kitchen so it would mean leaning the whole assembly at an angle with associated risk to sink cutouts etc.
Second idea is to screw some 2x1s underneath across the join and wedge the lower end and tighten the screws to get alignment.
But is there a trick that the pros use that I am missing?
Andrew
Andrew
