No RK and a 60hz motor by the looks of it = no good full stop, never mind the postage/customs.
Proxxon or something else might be worth looking into.
All these wee saws are a bit dodgy being so close to the blade, i.e it doesn't make life easy for
one who wishes to go by the H&S advice/or regs in industry, by using 450mm push sticks.
and something so light would need be clamped or bolted down, which seems like a bit too much
work to be done to a new machine.
I'm going to be contradictory with my advice, which is not to follow advice from any Yankee's
as the figures speak for themselves, seemingly the sawstop machines are becoming the norm with the antics they get up to.
Bottom line, if you're getting advice from someone with a Sawstop...
then you'd better get one too.
First to start off with is Roy Sutton, and then some merican productions after that,
Although you should be looking at Steve Maskery's advice here or TWH2 to ensure Roy's stuff is up to date, or other little things which may catch you out,
Best to ask UK woodworkers if unsure.
Roy Sutton
American production! with Kelly Mehler
American production which goes through a lot of safety, though citation needed, as with all non HSE stuff, there is some stuff there which is worth a watch.
Gwinnett woodworkers safety tips video
and another fella who visits the group, Ted Baldwin, (who's videos I must watch again)
to see if as safe as possible.
Always look for the same thing done in the UK, as folks who live this side of the ocean
will be more trustworthy (from experienced hands that is)
as they would get chastised by their fellow craftsmen.
Those same fellow craftsmen who may not bother with the constant crusade trying to get the rest of the world to see some sense in regards to keeping ones digits.
Some Steve for a base line, even if you may read some negative comments regarding his suva guard (which is fair enough if you ask me)
Nevertheless, Steve is actually willing to try and teach, show things with clarity,
as many of the folks who condemn his publications never seem to offer a decent alternative
which actually has substance, i.e thorough enough to cover/address everything,
and not just a catch all sentence which takes little effort, and doesn't really answer anything.
Good luck, and ps, I do hope you have a method of surfacing your timber beforehand,
i.e hand plane or by machine.
Tom
