HeathRobinson
Hi, (newbie alert)
Not quite as dramatic as the title suggests, however I did see a few embers fly out at which point my brain worked out that the burning smell must be the wood and I switched off. I'm only trying to make a shooting board out of scrap chipboard, not start a BBQ. I don't have a table saw because I basically work among the sofa's in the living room at present which I hope explains away what I'm doing using a jigsaw to cut straight lines.
I'm using a little 'shed' branded jigsaw with bosch blades that claim to be designed specifically for chip board and soft wood. One is now quite badly blackened from the experience.
What is going on? With this same chipboard I experienced what can best be described as resistance at random points along the cut last time I cut it. Could it be that this chipboard contains nasty stuff like metals? I notice that despite using a guide that the cut becomes decidedly skew in the vertical plane at around about the point the trouble started.
Think I'll leave this well alone for a while and go and get the shooting board parts cut for me.
Simon
Simon
