Stormer1940
Hi guys, I'm looking to make a toy box and was thinking of using box joints on the corners. As the box will be approx 600mm high there will be rather a lot of joints to be cut. Rather than purchasing a rather expensive 600mm jig for the process; What jig could be made up to achieve these joints on a bench saw? I've read about dado cutters and peoples hate for them so a little confused as where to go because obviously the dado cutter takes out a larger chunk of material than you would get with just a standard blade and would make the process quicker. The saw I have is an old Wadkin PKA. Any suggestions on jigs and the best and safest way to remove material and cut these joints?
Nick
Nick
