Mine died two months ago, and more than a year out of warranty. I called Axminster Support for help in diagnosing the problem, and they sent me a replacement board FoC.
Hi steve did you ever sort out a control unit for your jet filtration system, l bought one recently second hand and plugged it in and turned on the main ant immediately started to make a rumbling noise and the fan turns slowly, l tried turning it on by the on/off button but nothing, then after a bit of research found loads of people suffering from a similar thing and by replacing the large square capacitor seems to have sorted them out but not for me,it still started up slowly just when l plugged it in but this time when l turned it on by the button the speed control section works and the led light up corresponding to the speed selected but no led for on or led for timer selection . I am waiting for the guy l bought it off to find the hand controller but it somewhere in a removal box , bit annoying as its been 3 to 4 weeks lve been waiting, should have told him l would have my money back but he seemed a nice guy and it was not a lot of money, even though it sounds like it may turn out to be expensive.Hi Jack
That's relay and fob link/idea is great, it was kind of what I had in mind, except I was going solid state relay. For around £7 it is worth a punt giving that set up a go. They even come with a project box! It looks like it would certainly be a quick fix, to ditch the Jet board and provide some basic remote function. I have not looked hard yet, but I have not seen one that provides a 'one relay on only' function. I suppose if one is extremely careful and turns all the speed relays off, before setting a new speed, then no harm will be down.
I have measured the motor current draw (running) at 142mA, 205mA, and 352mA (low, medium, high), so those miniature mechanical relays of around 1 amp or more should be capable, as long as they are good for 240V AC.
I am going to need a remote soon. Jumping up to turn the fan on and off and change speeds is going to get boring real quick (I need the mechanical rotary 4 position switch to be part of the unit).
I am still toying with the Arduino idea, as I can see complete control going down that route. Although more time consuming, the Arduino board could be made to replace the Jet board and could retain the 3 led speed display, and the run on timer and its 3 led display. There are other possibilities.
I will report back when I have made progress.
All the best
Steve
Hi thanks for reply, trouble is it's up on the ceiling so to try to use the buttons on the control is a pain,means climbing up on steps to start it and then to change speed. So really need remote or a wall mounted switch and a way of changing the speeds not bothered about the timer control.Why not keep things simple, have your filtration pluged into a socket that can be remotely operated, use one of these Remote Controlled Switch Box IP66 - 3 Gang
or to make it even simpler just walk over to it and switch it on manually. I suppose that is one of the benefits of growing up in the sixties before remote controls were invented. I will say that is a really crude and old fashioned circuit board, probably made by some asian in there house on peace work using recycled components.
Hi everyone, thanks for your replies, think l may have started a technical debate, unfortunately my electronics knowledge is limited to 1 year of radio/ electronics at college which ended after 1 year instead of 3 due to lack of funding of my employer the UEA and l was let go, but 51 years on and l can say l have always kept busy and hopefully will continue to. This problem with the pc board on these jet filtration units has been going on for years going on by the amount of references to it on the internet. If someone could actually diagnose the faulty components or weaknesses with a fix that would be brilliant, apparently some people have had 3 to 4 replacement boards over 6 to 7 years, some under warranty and some not. Thanks again.Yes that is a really bad design for a 5Vdc supply, If it was my design I would have used a three term regulator and not the Zener, normally used as voltage references and not actual supply. You could improve it by using a self contained 5 volt Dc switching supply and do away with all that other nonsense.
Hi Jack, well at the moment but who knows for how long, so taken in all options, keep up the good work everyone. .That's great Bob, glad you're up and running already.
Jack
