Hi Guys,
Complete novice but here goes...
Just reading through the the posts on this thread... you lot are the bomb.
I too have one of these machines that has... check this, done 1 hours work and developed the same fault as most of the posts but exactly the same as rogers's problem.
When pressing the buttons on the machine or using the remote, they don't ramp up the speed very much at all. Though I originally bought this machine in 2012, it has only done i hours work on low speed.
A long term illness and things on the house have turned a short term shop set-up into a long term shop set-up :evil: I had just switched on the unit to check it and had the same problem as all of you guys. The motor just doesn't get up to anything more than a gentle spin on low, med, or hi. Even on high you can still make out every single fin on the motor fan when viewed through the rear vent.
It did the same thing as rogersS when it was moved to the ceiling about a year ago i.e. even though it was switched off, it was making a grumbling noise and trying to spin the impeller.
Am wondering if replacing the cap with the mentioned RS on will sort mine.
Had a radge at Axminster tech guy over time versus use... deaf ears as you would expect. Said capacitor would be £17:40 but out of stock anyway for at least 5 to 6 weeks. I asked if this was a common fault and tech said he had never come across it before. Yeah... I bet.
Thanks fellas in advance if you could help a complete novice. Am completely fine with soldering etc.
Kind regards
Ian Dean
