stuartpaul
The downsizing continues and as I simply won't have the room the drum sander is next to go!
I bought it second hand in almost new condition from a member on here and haven't used it an awful lot. Comes with the extension tables and has (Jet) castors fitted to the base. Includes several loadings (80 grit x 2, 100 grit x 1, 36 grit x 1 and a roll of 60 grit to make your own. Is also fitted with either 100 or 120 grit).
This will fit in the back of a car when taken apart. Located in Somerset TA18. Would be prepared to consider meeting or travelling to deliver (within reason!) if that helps.
Price reduced to £600 or very near offer.
