Japanese stool. Finished with final work in progress shots
Pete W":2zrn27mc said:
Adam: just curious, but are you leaving all those sharp edges and corners on the seat? :shock: :lol:
No, I plan to round them off.
Gill":2zrn27mc said:
Like Pete, I think a bit of walnut detail on the other side of the seat would give it more balance.
Err, cough, due to a little breakout with the morticer, I think I may have just required myself to have a bit more walnut on the top. I may go for circles though, just to make it look even more odd. :wink:
Adam
PS: Note to self... When using a morticer on a curved unit, remember their is no support under the chisel and it'll break out and create large splits in the upper surface. :oops: . Ahh well, that'll teach me not to think about what I'm doing properly.
:lol: :lol: :lol:
Well done, Adam! I'm sure your stool will be all the better for it.
Gill
Well, back to it!
First up trim off the excess
Then get the smoother working..
Trimming some of the excess away
A first view of what it might look like..
Just look at the dust on that saw - shocking.
Next up trimming the shoulders.... (PS recognise the saw ALF?)
Cutting a curve using the crappy bandsaw.
Both sides complete.
Back out with the spokeshaves.
Chiselling up the edges.
Next up morticing the seat.
First cuts..
Bugger - I've gone right through. Oh well :roll:
Time to give up for the day!
Adam
Never mind, Adam - it's still coming on a treat. And I'm confident you must have some more mahogany lurking around somewhere to 'enhance' the piece ;) :) .
Gill
Onwards...
Cleaning out the mortices....
And trimming the tenons to size.
And putting a chamfer on the tenon.
First check it goes together! Yippee!
And from the side!
I've decided against the helix cross braces - its just too difficult on this as it requires so many compound angles.
Instead I've decided to go with horizontal braces.
Now I hate jigs,:twisted: as they take up loads of time, effort and materials, and the time spent making them could be spent building a project, or learning to do the task by hand. :? Anyway, on this occasion, I've decided to give in and build an angle bracket. :oops: I lashed two pieces of board together with a couple of hinges, and bar to set the angle. Total time, 5 mins. Thats just about acceptable. :p
Checking I've got the correct angle
Back on the morticer.
All of 1 side cut
Having cut the entire side, I noticed I'd got it back to front, so the angle I'd cut at the bottom, to make sure it sits level, is the wrong way round. Solution is either to make it slightly lower, or to add some more walnut to the base of the "legs", - which I think could look quite nice.
Adam
Hello Adam,
Looks great!
Wouldnt mind having a go at that project myself. And thanks for sharing the pictures of how your progressing.
simon
tim":zbq3aakb said:
Well done Adam - your honesty is inspiring! Cheers Tim
Someone on here, I'm not sure who, said something along the lines of the difference between a beginner and a pro is how they deal with their mistakes. I can kind of understand that, (although someone doing it professionally will have A) made the mistake once before and won't do it again, and B) will plan their work flow.) but I've definately become more confident at what to do after making a mistake. I currently have the following view on mistakes..... :oops:
Mistakes are inevitable for me, as I don't plan my workflow, don't work to a design, and am still inexperienced. However, most people don't notice them anyway, the fun is in the making an item yourself and it's not often you can't do something to partially remedy the situation. So I don't worry about it anymore. Once I've made a mistake though, I don't ever try to remedy it until the following day, when I've had chance to think it through.
Adam
Really coming together nicely Adam. The small mistake will soon be a feature :wink:
Hmm, some comforting reassurance. I have to look on the bright side otherwise I'll realise I'm completely incompetant at executing the construction of even the most simple item :roll: :oops: :oops:
Adam :?
Adam
When I was a mere mechanical engineering apprentice serving my time 5 years plus 6 in college. I always remember my spell in the toolroom making moulds out of meanite ( a form of cast iron ) the instructor old Sid Chambers was in his seventies. His advice was always that a good tradesman is able to correct a mistake so that it does not exist or it looks as if it should be there. I think that was sound advice and after 50 years I still remember it. Nice piece of work.
Les
Tsk. It's not a mistake, it's a Design Opportunity. :roll:
And yes, I do recognise the saw. Hope it's okay. Sorry for not commenting before, but I was hoping I'd be seeing it unroll at speed right before my eyes courtesy of broadband - alas, that's deferred until next week now. :( Actually I don't think I'll say anything even now. I'll wait to see how it turns out - bit of a moving target at the moment. :D
Cheers, Alf
Hi Adam,
Any more progress on this? Or are you too busy with your shiny red tractor! :wink:
Howard
Some, but not enough to justify taking some photos. I've fixed the top, turned a couple of washers to fit the damage of the mmorticer breaking through glued and planed them, trimmed the tenons slightly as they were binding.
Adam
Mcluma":1f5s36nb said:
He Adam is that a Massa Ferguson tractor your sitting on :?:
Indeed. A 35X, its my uncles.
Adam
Right skip forward a few evenings (I've started another project) so this got on the back burner.
Anyway, here's a couple of the finished item.
Its had a few coats of oil - all it needs now is some beeswax polish and it can be brought back in the house.
Adam
That's looking mighty good Adam. Especially the wedged tennons, very nice.
Noel
