Mittlefehldt
dchenard":32k9p5y9 said:[quote
Was it this one?
That's the first one I bought, and it is indeed fragile. I think the steel is hardened beyond its capabilities, making the teeth brittle. For the record I have not broken teeth on the other dozuki I own or owned. I would suggest you try again with that Z Saw I mentioned, Langevin & Forest sells it, and other outlets I'm sure.
DC
No it was not, I do have that one though used it to frame a basement room worked okay in construction grade spruce, ie soft, but wobbled all over the place and I couldn't cut a straight line with that thing to save my life.
The one I am referring to was called Japanese Dovetail saw, and it now has a black handle rather than the light coloured wood one mine did. As I said earlier it was fine in white pine dovetails but as soon as it got to anything with some weight it started losing teeth, and I would be the first to admit that my technique or lack thereof may have been responsible.
However I have as a result of reading Adam Cherubini and others discovered that western saws do the job handily, if you sharpen them, which I do, again maybe not flawlessly but I notice an improvement before and after. So I will stick with my little Pax and my R. H. Smith or Shurley & Dietrich made in Canada saws.
I should add that the first saws I bought for woodworking were the LV Japanese saws and I can say I prefer the western ones I use. You cannot beat the price when you see them regularily for less than $20 Canadian, and they do the job handily.
