Is this Tanin staining?
Andy's Shed
13 Aug 2022
York
Yesterday I turned a bowl from an Oak crotch that I'd been given and as it still had a high moisture content, I'm expecting some wood movement, cracks, etc.
I brought it indoors and I'm just going to leave it to thoroughly dry out, but this morning I noticed some grey coloured blotches and patches in places.
Is this the Tanin in the wood rising to the Surface and is it likely to remain once the bowl has dried? If so, what would be my best bet to try and remove or reduce it?
Here's a photo of one of the offcuts. Thanks 👍
You get that if there is a reaction between the tannins, particularly but not exclusively in green oak, and ferrous metals. Has it been in contact with steel? A few weeks back I sanded a small piece of well seasoned oak on a belt thal had also been used to sharpen a chisel, my mistake. Glued it up, a day later there were black lines ion the joint. You can get staining where the chuck contacts the bowl tenon or recess as well.
Thanks Richard and Phil, yes it's likely from metal tool contact.
I have since done some searching online and Oxalic acid was mentioned in several videos, we have some Barkeepers Friend cleaning powder and it contains Oxalic acid.
I did a test spot in the centre of the oak cutoff and it did a good job of removing the stain. After seeing the test result, I've just gone over the bowl and it's looking much better now. Many thanks again.
If you use titebond it reacts with iron leaving black marks. Steel sash clamps without masking tape over them are a no no for panel glue ups.
Andrew
