Flartybarty
I recently bought a job lot of planes which included one metal "half infill" and four wooden planes. All the wooden planes bar one were by Mathieson. The metal plane is jack size, has no makers mark on it but the blade is unusual and is stamped with the Mathieson mark. I would like to know if this is actually a Mathieson plane. Did they make hybrids such as this one ? As you can see from the pics, it has a bailey type frog and blade adjustment but has an overstuffed wood (I think mahogany) front bun. The bun is held by four screws, only two of which I've been able to get out (they were obviously a later addition) while the toat is held in place with rivets. The frog is a very heavy bit of kit with the yoke in cast brass. The securing screws are dome headed and, regrettably, pass through the sole. The screw holes do not line up at 90 degrees to the body - they're off by a fraction. While it is tempting to think that this is a panel plane which has been "modified" by someone, there is no indication that a brass/gunmetal lever cap has ever been fitted. Given the design of the frog, it seems that the lever cap would have been the Stanley type (it's missing, unfortunately). Also the toat has been installed by someone (professional or otherwise) who definitely knew what he was doing. The parallel blade is 5mm thick (3/16") and seems hardly used. It is unusual in having only a small slot to fit onto the frog so it's definitely intended for this plane. There is no mark anywhere on the plane - not even a users stamp. The guy I bought it from is located in Prestonpans (Scotland) which, in company with the wooden planes, inclines me to the belief that this may be a Mathieson. Whether it is or not, it will make a nice addition to my toolchest once I've located a suitable lever cap.
