Good evening,
Disclaimer: This is not a pure sharpening thread about what technique is the best for splitting atoms with the blade, so only popcorns up to 300 ml in volume are allowed.
I am grinding a camber on my jack plane with a rather pronounced radius on a bench grinder for fast wood removal. However, after a few sharpening sessions on the stones, my camber approximates to zero. I try to apply more finger pressure at the ends of the blade and less in the middle, but eventually I get a flat edge anyway. Is this normal and I have to regrind the camber after it becomes flat or I am not doing it properly and I should be able to create camber only once and then just maintain it indefinitely?
I am able to maintain slight camber on a smoothing plane, where only few hundreds of mm are needed, with finger pressure, but I am not able to maintain a bigger camber of jack plane without making the edge straight by consequent sharpening sessions.
I do not mind using the grinder, but my blades would become too short too soon.
Thank you.
Thank you.
