May I ask four things
1. Are you hobby or professional?
2. How much space do you have for woodwork?
3. What sort of things do you make / would you like to make?
4. Is cost a major factor in your decision making or will you buy once, cry once and buy the very best?
I don't know if this was an open question, but here goes.
1. I am strictly a hobbyist.
2. My shop is in a 5x10 meter area of the finished basement. I divided it in roughly two equal areas with one area for the large dust and chip producing equipment that requires connection to the permanent dust extraction. The other area is for the portable equipment that can be connected to a vacuum, hand tool workbench, 1x2-meter assembly table, and computer workstation.
3. I will be making household items, such as bookcases, cabinets, shelves, bathroom vanities, built-in closets, and eventually a new kitchen.
4. Cost was not a factor in my decision making process, and I eventually replaced all but a couple of powered tools with Festool products. The only tools I didn't replace were a Bosch cordless drill and two Bosch cordless impact drivers. The factors that drove me to Festool were durability, dust collection, and availability.
Had I done more planning and analysis in the early stages of shop equipment acquisition, I would have started with Festool instead of transitioning into the Festool line. The ability to safely use all of the tools inside the enclosed basement instead of split operations between the garage and basement was a significant advantage. I'm sure other manufacturers have similar product lines, but the Festool routers, Dominos, random orbital sanders, and track saws share the same CT26 vacuum system (with Oneida cyclone) and are now inside tools instead of outside or garage tools. The chip collection on the PS300 jigsaw is not impressive, but significantly better than the Bosch jigsaw it replaced.
An equally impressive improvement on dust and chip collection was replacing the DeWalt DWS780 miter saw with the Kapex 120. Whenever I used the DWS780, I monitored the dust with the Dylos DC1700 air quality meter. When the readings on the Dylos increased to about 750 above the ambient particle count, I stopped and let the Record Power AC400 run for about 20-30 minutes, or until the particle count dropped near the initial ambient levels. With the Kapex and the dedicated CT36 vacuum, the particle count never exceeds 250 above the ambient level. Cleanup after a long session with the DWS780 took about 15 minutes because the chips were all over the shop. Cleanup after a similar session with the Kapex is about one minute since all of the chips were at the saw.
The ability to safely use these tools in the basement means I can work any time I want and not be bothered with the mandatory quiet times during the day or all day on Sunday and federal holidays. I might decide to break down large sheet goods in the garage if I'm working alone and will have to work around the quiet times. Otherwise, I can bring a full 8x4 sheet of 19mm plywood down the stairs and into the shop if I have another set of hands.
