Introducing the NEW Pow-R-Tek SR Router from JessEm
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Designed and Engineered in Canada
JessEm’s Pow-R-Tek SR Router is a powerful 3-1/4hp motor 100% designed, engineered, and tested by JessEm in Canada. This router motor has been in the design and production stage for over a year to ensure that every aspect of it is perfect. JessEm tore apart every router currently on the market to figure out the positives and negatives of each to design what they believe to be the absolute best option available.
£609.95
Powerful Motor
Powerful soft start 3-1/4 HP motor with electronic variable speed control 10,000 to 21,000 RPM​
Steel Control Box
Steel variable control box features a digital display, adjustable speed dial and a no-volt release switch​
High Performance Bearings
Double-sealed angular contact bearings rated for 30,000 RPM provide stability and durability​
Optimised Air Flow
Dual airflow ports at the bottom of the motor take in fresh air to prevent the motor from overheating​
NEW Rout-R-Top and Fence
JessEm MDF Rout-R-Top
£229.96​
Buy Now
JessEm Rout-R-Fence II
£259.96​
Buy Now
JessEm ALTS Router Table Stand
£449.95​
Buy Now
JessEm ALTS Double Locking Castor Set
£289.96​
Buy Now
